Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Receivers to go with the Orb Audio Mo...
Author Thread: Receivers to go with the Orb Audio Mod2 speakers???
Username: Sw345
New York, New York
Usa
Please, please, please...any recommendations for a receiver. I live in a cramped apt. in NYC, so I think these speakers will be perfect.
Username: Project6
Post Number: 11365
Budget?
Username: Sw345
New York, New York
Usa
$600-800...
Username: Project6
Post Number: 11366
Pioneer Elite VSX 81 or 82. I believe you can find the 74TXi within that budget if you look hard enough.
There's also HK AVR 445 and HK AVR 635. you can find these on amazon.com, I believe they are on sale.
Excellent receivers and should work well with your Orbs.
Username: Sw345
New York, New York
Usa
Thanks Berny! I found a thread earlier all about these orbs, and the Denon 2807 was recommended, so I'll look into that as well.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Receivers to go with the Orb Audio Mo... [ « Previous ] [ Next » ]
