Thread: How much difference does my Co-axial cable make? |
New member Username: Gniffer
Post Number: 4 Registered: Apr-04
| Posted on Sunday, May 09, 2004 - 11:35 pm: |
Hi all, I am running cable-TV through a VHS system and using the VHS phono out to put the audio out through my Audio amp & speakers (I do not have surround or AV receiver) My question is; is it worth spending money to upgrade the coaxial between these components or is the (presumbly) analogue cable signal through the VHS not pure enough to warrant the outlay?? I currently have the cheapy co-axials supplied with stereo equipment Cheers, Rich Daly |
Post Number: 5 Registered: Apr-04
| Posted on Sunday, May 09, 2004 - 11:45 pm: |
Errandum; When I said co-axial I actually meant audio RCA cables!! Cheers |
Silver Member Username: Project6
Post Number: 558 Registered: Dec-03
| Posted on Monday, May 10, 2004 - 07:26 am: |
save your money to buy better equipment and not cables. |
Silver Member Username: John_s
Columbus,
Ohio
US
Post Number: 112 Registered: Feb-04
| Posted on Monday, May 10, 2004 - 07:54 am: |
Rich: For many years I used to have my system hooked up the same way. My advice is basically if it ain't broke, don't fix it, that is if you are happy with the sound. But, in my experience, it is very possible that cheapie patch cord will eventually fail: channel drop-out and/or noise. Use the opportunity to upgrade then. BTW, you didn't specify, but if you are using a newer cable box with audio R/L outs, you should be using those instead of the line output on the VCR. |
