Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Onkyo TX-DS676: I have sound, no vide...
Author Thread: Onkyo TX-DS676: I have sound, no video. Looking for advice; I've given up
Username: Sven_k
Toronto, Ontario
I'm hoping that someone can point me in the right direction. I've gone through various hook-up configs and can only get audio. I've gone through the Onkyo manual many times looking for some reference as to why this may be happening with no luck.
I have both S-Video and RCA connections from the receiver to the monitor as directed by the manual. I know that the receiver is putting out some information as I get on-screen menus from the receiver's set-up area but that's all. I have for example, changed the DVD input to Video 1, 2, etc but it is the same result.
I am able to hear the sound from a DVD, from my VCR, from the tuner and CD but none of the video comes through.
Any help or guidance is most appreciated.
Username: Project6
Post Number: 557
are both RCA and S-Video cables connected? You can only use 1 or the other, not both.
You did not specify the type of video connections that you have done, so it will be difficult to pinpoint. Be specific!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Onkyo TX-DS676: I have sound, no vide... [ « Previous ] [ Next » ]
