Home > Message Board > Home Theater > Home Theater in a Box > Archive through December 29, 2006 > Onkyo HT-S790_using pivoted/tilt wall...
Author Thread: Onkyo HT-S790_using pivoted/tilt wall mounts with speakers
Username: Stklim
I want to wall mount my surround sound speakers using the Atlona angled wall mounts.
How do I attached the speaker to the mount since the speakers only have the keyhole slot?
Can I screw directly into the speakers?
Any chance of damaging them if I do.
I can not use the mounts that come with the system due to certain physical attributes to the room.
I also would like to wall mount at an angle the front speakers. Has anyone done this?
I had the room (new construct) wired for wall mounted speakers and did not realize the Onkyo speakers did not have one or two hole mounting ability.
Thanks.
BTW the sysytem wass easy to hook up even for a novice like me. Even with speakers not in perfect postions War of the Worlds sounded pretty excellent.
Home > Message Board > Home Theater > Home Theater in a Box > Archive through December 29, 2006 > Onkyo HT-S790_using pivoted/tilt wall... [ « Previous ] [ Next » ]
