Home > Message Board > Home Theater > Home Theater in a Box > Archive through December 29, 2006 > Do i need receiver
Author Thread: Do i need receiver
Username: Brgurung
hi, i am planning to get home theatre system....i am total newbie to this arena..... i have a dvd player with dts, dolby support...do i still need a receiver or just the speaker systems would do? as i am also low on budget, which one would you suggest among sony and onkyo?
Username: Samijubal
Post Number: 2973
You need a receiver to decode the surround signal and power the speakers.
Username: Project6
Post Number: 9583
If those are your only choices, go with Onkyo.
David is not a big fan of Sony's nor am I. But with good reason :-)
Username: Samijubal
Post Number: 2975
I'd take Onkyo over Sony, but neither would be my first choice.
Username: Brgurung
Hi, thanx all for the reply..... if not onkyo or sony, then what would you recommend for budget conscious like me.....max i'd go is around 500.....
Username: Project6
Post Number: 9610
HK, Denon, Pioneer.
Username: Samijubal
Post Number: 2978
You left out Yamaha.
Home > Message Board > Home Theater > Home Theater in a Box > Archive through December 29, 2006 > Do i need receiver [ « Previous ] [ Next » ]
