Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Optical or coax to 5.1 analog
Author Thread: Optical or coax to 5.1 analog
Username: Cooldude003
i tried googling and stuff but i couldnt get a perfect answer. is it possible to turn a optical or coax into 6 analog cables?
Username: Project6
Post Number: 9491
Yes, you will need a receiver.
huh?
the problem is my receiver only has the 6 analog cable inputs and my cable box only has coax,optical and left-right analog output.
Username: Project6
Post Number: 9502
What I was trying to tell you was, you will need a receiver that is capable of accepting digital audio. It is unfortunate but that is what you need.
What receiver is it?
You can also get a pre/pro that accepts Digital inputs and that has 6 channel analog outputs.
ugh i cant spend that much money. thanks for the help though.
Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Optical or coax to 5.1 analog [ « Previous ] [ Next » ]
