Thread: Is HDMI bidirectional? |
New member Username: Lovehitech
Post Number: 1 Registered: Jul-06
| Posted on Tuesday, July 25, 2006 - 03:21 pm: |
I'm hooking up a new HDTV and home theater with cable box. The Panasonic home theater SC-HT740 has only RCA left and right jacks, and an HDMI jack labeled "output." It has no coaxial or optical inputs. So am I correct that there is no way to send 5.1 channel sound into the home theater unit? Or is the HDMI bidirectional, so I can feed 5.1 sound into that jack? The manual and Panasonic Help Line say just hook up the RCA jacks. |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 1039 Registered: Feb-04
| Posted on Tuesday, July 25, 2006 - 08:43 pm: |
So am I correct that there is no way to send 5.1 channel sound into the home theater unit? Or is the HDMI bidirectional, so I can feed 5.1 sound into that jack? Yes, and no. |
Post Number: 2 Registered: Jul-06
| Posted on Tuesday, July 25, 2006 - 11:35 pm: |
Thanks for your reply, which confirms my findings from more investigation today. I hadn't understood that there's a difference between Dolby Digital 5.1, which requires digital input, and the more elementary Pro Logic, which I now realize is all this system can do. I also learned that the unit has the HDMI output because that's necessary to take full advantage of the upconversion DVD player video it has. |
Columbus,
Ohio
US
Post Number: 1041 Registered: Feb-04
| Posted on Wednesday, July 26, 2006 - 07:21 am: |
Exactly. A little research before purchasing is a good thing.
