Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Paradigm & Yamaha?
Author Thread: Paradigm & Yamaha?
Username: Bluehawki
U.S.A.
Any thoughts on my idea for this set up?
Paradigm:Speakers
Titans: for fronts
sub: PDR-10
Center: cc270
Cinema 70s for rears
Powered by Yamaha RX-659BL
70%HT/30%music All under 2,000
Can i do better w/ my selection or movr on!
Username: Project6
Post Number: 8867
Not a bad set-up. Go for it!
Yamaha and Paradigm really play well together.
Username: Bluehawki
U.S.A.
Thanks Berny Lots to look at head spinning at times!
Berny any idea about speaker wires I have wires already for the rears. Not sure for the rest?
Username: Project6
Post Number: 8871
14 gauge will be fine.
Username: Bluehawki
U.S.A.
Berny your thoughts on Paradigm rears, dipole vs directs. My space is 15x16 with the couch 1 foot out from rear wall. Is there any other rears speakers that will work well with Paradigm system.
Username: Project6
Post Number: 8942
Dipole vs directs are a personal choice. Anyone who does not have your ears cannot quantify which sounds better, only preferences dictate that which you will like.
Stick with the Paradigms all around, I don't believe you can go wrong with that choice.
Username: Bluehawki
U.S.A.
Post Number: 7
Thanks Berny, just got back from the store and placed an order For the following set up:
Paradigm Mini Monitor for the fronts,
CC-370 for the center
Cinema 90s For the rears,
PDA-10 for the sub.
Powered by the Yamaha RX-659 comes w/ ipod dock.
Up here in Taxachusetts we are have two tax free days in August. I can p/u all for under 1,900.00
Not bad?? Wish me luck!!
Thanks again..
Username: Project6
Post Number: 8960
Nice, very nice! Good luck and enjoy your new toys!
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Paradigm & Yamaha? [ « Previous ] [ Next » ]
