Home > Message Board > Home Theater > Home Theater Computers > Connect a laptop to the TV & get soun...
Author Thread: Connect a laptop to the TV & get sound
Username: Raju1973
I have connected my laptop to the TV, but the sound comes out of the laptop speakers. What wires & connections do I need to use to get the sound from the TV?
Thanks
Username: Project6
Post Number: 8801
You need an audio connection from your laptop to the tv. You have only connected video.
You need an audio cable to connect to the audio input of your tv.
Username: Nency
I agree with Berny you need to get an audio cable and connect the audio input to your TV and output cable to your Laptop and you are done.
Username: Goodlooker
Stamford, CT
United States
I want to hook up my plasma to my computer as well. All I see on the back is a 9 pin connector, hdmi, s video and rca cords... can I do it?
Username: Lucky101
Hydeabad
United States
Post Number: 21
Hi Stephen, Yah you can connect your pc to Plasma. For audio output you can use either audio out cable or connect your laptop with good speakers.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Computers > Connect a laptop to the TV & get soun... [ « Previous ] [ Next » ]
