Thread: ONKYO HTIB receiver - hot temperature |
New member Username: Bentot
Post Number: 1 Registered: Jul-06
| Posted on Thursday, July 13, 2006 - 11:50 am: |
I just got a brand new ONKYO HT-S790 HTIB and placed it inside the tv stand with an open front and back. Just wondering why? for a couple of hours of zest from listening, the receiver becomes very hot, is this normal? |
Bronze Member Username: Gamerdude
Ontario
Post Number: 93 Registered: Apr-06
| Posted on Tuesday, July 25, 2006 - 07:48 pm: |
yes it all depends on how loud your playing your music if its loud that make the amp work harder adn if it normal temp's over a period of time yes it will get hot |
Bronze Member Username: Mmastin
Colorado Springs,
CO
Post Number: 18 Registered: Oct-05
| Posted on Friday, August 11, 2006 - 10:58 pm: |
I have a small fan on mine...I face in downwards on the top of the receiver. Keeps it much cooler. I worried about that since it is in a somewhat closed area in my entertainment center. |
New member Username: Kevin_l
Post Number: 1 Registered: Sep-06
| Posted on Saturday, September 16, 2006 - 12:47 am: |
Having a similar issue w/ the same unit. Ran so hot it quit working after 2 hours. [three days out of the box] Thermal cutout I suspect. Went to local authorized service in San Diego. After a month [7 to 10 days turnaround is what they said] they told me that there was nothing wrong with it. I picked it up and plugged it back in, 2 hours later same problem. Wish me luck with third call to corporate support, maybe they will actually fix or replace it. If I get any answers I'll post what I find. [6 weeks and still waiting ] |
Gold Member Username: Samijubal
Post Number: 3053 Registered: Jul-04
| Posted on Sunday, September 17, 2006 - 12:53 pm: |
I use 2 PC power supply fans on my receiver, 1 between the transformer and heat sink, the other on the opposite side of the heat sink. They blow out, not in. Works great. |
New member Username: Flags
Post Number: 4 Registered: Jan-07
| Posted on Sunday, February 18, 2007 - 07:00 pm: |
You need to have 18 inches above and 8 inches on all three sides in an open area. I keep mine on an end table and have no problem when running volume at 45 for 14 to 16 hours straight. |
Gold Member Username: Arande2
400dB could probably d...,
SouthWest Mi...
Too Many DBs...
Post Number: 1251 Registered: Dec-06
| Posted on Sunday, February 18, 2007 - 07:28 pm: |
I run mine in a very tight space and it takes around 12 hours to get hot running at around -5dB, 4 hours when satellite or dvd is on. |
Platinum Member Username: Project6
Post Number: 13053 Registered: Dec-03
| Posted on Wednesday, February 21, 2007 - 05:19 pm: |
What speakers are you running with this receiver? chec |
Colorado Springs,
CO
Post Number: 30 Registered: Oct-05
| Posted on Wednesday, February 21, 2007 - 05:27 pm: |
As with many high output receivers you need a fan on them. I remember in college dorm this guy use to have a good size fan on his receiver. Anyhow, PUT A FAN ON IT. I have a very small fan...maybe 4" in diameter on mine. Gets warm, but never too hot nor does it stop working...and I crank it with movies on. |
