Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Only sound from one speaker, help please
Author Thread: Only sound from one speaker, help please
Username: Stevo__
Hi i have 5.1 surround sound card and speakers ( one center 4 speakers and sub) My 5.1 sound card takes 3.5mm jacks so i bought 3 double phono to 3.5 mm to go from the sound card to the subwoofer, i only ever get sound out of the center speaker, can anyone help me?
Username: Project6
Post Number: 8456
Have you read the doucmentation that came with your sound card? Contact tech support.
Username: Stevo__
No, i bought it off ebay so none came with it, the other odd thing is it is a PCI card which fits in the slot but there is a gap at the end so it fits but is too short, i'm not sure if this is the problem? It is a yamaha sound card im pretty sure. Have i set it up properly with the correct leads?
Username: Stevo__
when i plug it in just using the AUX (not 5.1) into my old sond card it works fine, but it is only virtual surround as its not a surround sound card
Username: Stevo__
can anynoe reply please?
Username: Project6
Post Number: 8572
Verify the brand of the sound card. You cannot assume or you will have more trouble trying to make this work.
Are you sure its PCI and not PCI-e?
Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Only sound from one speaker, help please [ « Previous ] [ Next » ]
