Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 04, 2006 > Best way to setup a 7.1 system?
Author Thread: Best way to setup a 7.1 system?
Username: Hannjeff
Halifax, Nova Scotia
Post Number: 46
My current system consits of all paradigm speakers, monitor 9 fronts, about 3feet from my tv on each side, my center is the cc370 directly above (cant fit udner), and my rears are adp370 dipolars that are same distance apart as my fronts and are about 2 feet behind the couch wall mounted facint front. Im palnnign on jumping to 7.1 as soon as I get a new reciever and I want to know how will my setup change. Ill be getting bookshelfs, probably monitor 3s or 5s, will those be my surround sides, and have them on stands a foot out from each side of the couch?, or will they be my rears?
Username: Chitown
Post Number: 1124
What do you hope to get out of a 7.1 system?
Username: Hannjeff
Post Number: 47
Um, well, surround sound my movies. A more theator experience. Basically, I want to feel like im in the movie. However, I want it accurate, the odd time I have a movie that supports 7.1, I want it to be perfect.
Username: Chitown
Post Number: 1128
As long as you are aware that there are few if any movies in 7.1
Here is an article
http://forum.ecoustics.com/bbs/messages/34579/129023.html
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 04, 2006 > Best way to setup a 7.1 system? [ « Previous ] [ Next » ]
