Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Compatibility craziness
Author Thread: Compatibility craziness
Username: Googi
Ontario
Post Number: 55
ok ok, I have a 5.1 surround sound Pioneer Receiver. will it work with 4 JBL speakers and 1 Infinity Sub? can all these brands be Compatible? if not, what should I change, because I didn't get the sub yet.
Username: Project6
Post Number: 8443
Yes, it will work with JBLs
Username: Compumasta
Post Number: 11
Yes it will work but it sounds like you may go without a center channel. There may be an option for no center on the reciever. If there is, and you are not going to have a center channel use the feature to output the sound to the other front speakers.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Compatibility craziness [ « Previous ] [ Next » ]
