Thread: Speakers with the Denon |
New member Username: Rrio16
Jakarta,
Indonesia
Post Number: 1 Registered: Jun-06
| Posted on Wednesday, June 28, 2006 - 06:48 am: |
I have just purchased the denon 2807 and what front speakers would match it. Music I listen to rock, and alternative. Most of the time Loud. Movies All sorts, all the time, loud as well. Can any one recommend me speakers to match the superb denon? Thanks |
Gold Member Username: Chitown
Post Number: 1113 Registered: Apr-05
| Posted on Wednesday, June 28, 2006 - 11:48 am: |
What's your budget? What is available to you in Jakarta? Low end: Paradigm Mid low: B&W Mid high: Monitor Audio |
Jakarta,
Indonesia
Post Number: 2 Registered: Jun-06
| Posted on Wednesday, June 28, 2006 - 11:56 pm: |
Most brands are available except paradigm. however i have the ps1200 paradigm sub which is quite good. What models B&W and Monitor audio do you recommend |
Post Number: 1117 Registered: Apr-05
| Posted on Thursday, June 29, 2006 - 12:10 pm: |
Again that depends on your budget and the size of speakers you are looking for. The 602's are probably a good middle ground http://www.bwspeakers.com/index.cfm/fuseaction/products.models/label/Model%20DM6 02%20S3 |
