Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Subwoofer,volume level,
Author Thread: Subwoofer,volume level,
Username: Coolbreezinnh
Lebanon, Me
Hey guys I need some advice on a few things that have been driving me crazy over the last couple of days.
My old receiver was a Denon AVR-683 it came with a surround sound speaker package. It did its job for a year but I needed to upgrade so I went bought a Yamaha HTR-5750 6.1 dts dolby digtial. Their have been a few issues that I have with old and new, my problems are...
I'm not getting the punch that I would like to from my subwoofer. When the base hits, its almost like a muffled rumble (no punch to it). I have my LFE level set at 100 I'm using my old subwoofer from the Denon package, also the surround and back speaker. My front I have replaced with a pair of Athena Towers, these sound good. Is it my Subwoofer or my settings??
Also while setting up my receiver I seem to notice that the front chanels seem to drownd out my center chanel. I have set my center chanel level higher than my front chanels. Will this hurt the clarity of the sound?
Username: Project6
Post Number: 545
most likely the set-up.
go through it from the beginning and make sure that the speaker levels sound the same when the test tones come on (use a VU/noise meter,if not just wing it).
Is your subwoofer powered???
Lebanon, Me
yes the sub is powered,its hard to tell if they sound the same cuz of the tone sounds is different.
i had the level set the same on the settings and it drown's out the center ??
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Subwoofer,volume level, [ « Previous ] [ Next » ]
