Thread: New SONY HTDDW700 setup with cables ??? |
New member Username: Prashanthchou
Post Number: 1 Registered: Jun-06
| Posted on Monday, June 26, 2006 - 11:19 am: |
Hi All, I have purchased my first home theatre SONY HTDDW700 and started hooking up , need some help from some expertise from this forums. I have these things with me: 1) TOSHIBA TV ( 5 YEARS OLD) 2) SONY DVD PLAYER dvpns55p (new) 3) SONY HOME THEATRE HTDDW700 (new ) This is how I had hooked up: =========================================== VIDEO CABLE FROM DVD(OUT) => TV(IN) with AV CABLE yellow cable AUDIO CABLES FROM DVD(OUT) => HT(IN) with AV cable Red & White cable The above 3 are coming from one AV cable(yellow,Red,White ) given by SONY DVD player ============================================ ORANGE COXIAL FROM DVD(OUT) => HT (IN) given by Sony HT ============================================= On the HT I have selected the DVD player as the input and y'day night when I was playing some movie, I could see that the sound is coming but no t to its fully extent(not sure I might be thinking wrong). The MAX SOUND ON MY HT is 70 and when I put my HT in 50 I could see that its ok but its not that LOUD. Just wanted to know if I am missing something . (All I am using is a regular AV cable(yellow,red & white) and Coxial cable(orange) which came with my systems. Any help !!!!!!!!!!!!!!!!!!!!!!!! |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 237 Registered: Jun-05
| Posted on Monday, June 26, 2006 - 01:05 pm: |
Part of your problem could be a set up. Did you read the instuctions for the HT or DVD. You need to go into the DVD set up and turn on the digital out puts . Why they do this I don't know. How is that digital input on the HT labeled ? You need to be on that input to get sound. |
Post Number: 2 Registered: Jun-06
| Posted on Monday, June 26, 2006 - 02:44 pm: |
I did turn on the DIGITAL ON on DVD setup. HOME THEATRE INPUTS: Inputs and Outputs Analog Audio Input(s): 4 (Rear) Antenna Terminal(s): AM Loop, FM 75 ohm Coaxial Audio Digital Input(s): 1 (Rear) Optical Audio Input(s): 1 (Rear) Here is the link http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_Display ProductInformation-Start?CategoryName=&ProductSKU=HTDDW700&TabName=specs&var2= |
