Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Looking to buy HTiB...need epinions.
Author Thread: Looking to buy HTiB...need epinions.
Username: Bakakun
Okay, here's the deal. The family room is 30x18x11(LxWxH). The house is entirely tiled except for the bedrooms and the small living room; as well as being opened space.
What I want to know is if I get the Paradigm Monitor 5 HTiB: 2 Monitor 5, 1 CC-370, 2 ADP-370, and 1 PS1200, is the Integra DTR5.6 receiver an overkill or do I really need all the power? Are the Integras even good receivers? And is the Panamax Max5100 (line conditioner) even necessary? I am new to HTiB so any inputs will be appreciated before I spend $4k m/l. Thanks!!!
Username: Project6
Post Number: 8442
That is one heck of a set-up. I don't think it is overkill at all.
Username: Compumasta
Post Number: 12
I agree that should be good based on your room setup. I have never heard anything bad from those companies. Good Luck and let us know when you finish and what you think.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Looking to buy HTiB...need epinions. [ « Previous ] [ Next » ]
