Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Speaker Wire Out > Low level in - wha...
Author Thread: Speaker Wire Out > Low level in - what to do?
Username: Slate
I got a JVC 6.1 dvd player & amp. the speakers (including the amp) all have speaker wire out.
My speaker set has a powered sub, with all the inputs into it. All the inputs r speker wire, except for the sub, whivh has L&R low level input, as a phono connectio.
The dvd player/amp does not have low level out :-(
ne1 got ne suggestions? any help is appreciated!
Username: Project6
Post Number: 535
are the DVD player and amp separate units? What kind of DVD player is it? If it has a line level output, such as L/R channel output, you could try using that to connect to the sub. If it has a 6 channel analog output, you can use the subwoofer or LFE output.
Check the amp if it has LFE out, usually only 1 RCA jack, then use that.
what model are we talking about, maybe that will help determine the type of connections you need. Still have the manual?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Speaker Wire Out > Low level in - wha... [ « Previous ] [ Next » ]
