Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 04, 2006 > 2 Digitals coaxes into 1 input? Baffled
Author Thread: 2 Digitals coaxes into 1 input? Baffled
Username: Pga71
I went through all the messagas, one was close to my question, but no answers.
So here goes.
My reciever has "1" digital audio coax input.
I want to feed two units to it w/o always unplugging my DVD Plyr or Cable Box.
1)Is there an A B switch or selector that handles this? I have not found one anywhere including radio shack and on-line.
2)If one does not exist, can I use one that has composite and jusy use that? or will the 5.1 not be passed this way?
3)Are the RCA plugs any different for other inputs as well such as composite, component video, right, left ect.?
Thanks
Username: John_s
Columbus, Ohio
US
Post Number: 979
Peter, here is a switcher but this is pretty expensive solution at $200.
http://www.gefen.com/kvm/product.jsp?prod_id=2616
If your receiver has an optical Toslink input, you can get a converter for coax (S/PDIF) ® optical.
http://www.ramelectronics.net/html/audio_toslink_adapters.html#pof-820
Username: Mccambley
BREEZY POINT, NY
Post Number: 214
Peter are ther any Digital Optical inputs on your receicer. What model receiver do you have?
Username: Pga71
Casey,
my reciever is a Bose Life Style 12, with only one digital coax input, no optical.
Don't want to upgrade yet since just bought the Plasma this week.
My TV is the 5060HD Pioneer 50" Plasma.
My cable box has both outputs.
Username: Pga71
John,
Thanks.
That switcher is just what I need.
I may have to bite the bullet for the $200, because I have not seen anything cheaper or anything close to this.
Actually for this price, I may just buy a cheap reciever to split the 5.1 into my Bose.
Username: Mccambley
BREEZY POINT, NY
Post Number: 215
Peter bite the bullet and get a real receiver to go with that plasma. Denon anyone.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 04, 2006 > 2 Digitals coaxes into 1 input? Baffled [ « Previous ] [ Next » ]
