Thread: Speaker placement before the walls go up. |
New member Username: Sinnier
Post Number: 1 Registered: Jan-05
| Posted on Thursday, June 15, 2006 - 04:02 pm: |
Hey All, So I just bought my 1st home and have a 30 x 15 foot room to use as a home theater. The problem I'm having is I want to wire the system before I put up the drywall. Now the speaker placement is my problem. How do I figure out where the speaker wall jacks will go? I don't have the seating yet and I wanted the floor to be in 2 levels. If anyone has any ideas, please post. The setup is a 7.1 Thanks SINnier |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 209 Registered: Jun-05
| Posted on Thursday, June 15, 2006 - 06:50 pm: |
Tyson this might be a little over the top but check it out. http://www.ultimateavmag.com/news/10388/index.html |
BREEZY POINT,
NY
Post Number: 210 Registered: Jun-05
| Posted on Thursday, June 15, 2006 - 06:54 pm: |
Tyson this may helphttp://hometheatermag.com/bootcamp/137/ http://hometheatermag.com/bootcamp/137/ |
Post Number: 2 Registered: Jan-05
| Posted on Thursday, June 15, 2006 - 09:07 pm: |
I'll take a look at these URL's when i get home later. Thanks. I just don't want to put in wall jack, just to find out the should have been 2 feet to the left or right or up or down. I know even seting it up the room i had it in took a bit to find teh sweet spots for the speakers. I want to make the room right. I have the gear just never had a good room to set it up in. If the room construction take a year that I fine with me. Thanks Tyson |
Post Number: 3 Registered: Jan-05
| Posted on Sunday, June 18, 2006 - 11:34 pm: |
Casey, This URL (http://hometheatermag.com/bootcamp/137/) is way cool. Its answers a lot of questions I had about different things. The room is barebones at the moment, so I can do whatever I want with it, and take as much time as I want. It won’t be a Million Dollar Home Theater but it will be the best experience it can be. I’m also looking for a good priced Canadian shopping website for Home Theater Chairs & decor. Thanks once again, I will share this website with others Tyson |
