Thread: Digital audio cable hookup |
New member Username: Ma3572
Wilmington,
Delaware
Usa
Post Number: 1 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 01:57 pm: |
I have a satellite recvr w/optical audio only connect and a a/v recvr with optical and coaxial connect and a dvd player with coaxial connect only. Should I run both an optical cable from the satellite recvr and a coaxial cable from the dvd player to the a/v recvr ? Or is only one digital cable needed form one or the other sat. / dvd player to the a/v recvr? |
Bronze Member Username: Floyd_1977
Plainfield,
IL
Post Number: 54 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 03:07 pm: |
You need to connect both. Otherwise, I'm not sure how you would expect to get audio from both components to your receiver. |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 204 Registered: Jun-05
| Posted on Tuesday, June 13, 2006 - 03:28 pm: |
Each device needs its own digital cable connection |
