Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 04, 2006 > Reciever shutting self off
Author Thread: Reciever shutting self off
Username: Nathan2239
ok i have a KENWOOD KR-V6060 i works great. heres the problem i recently moved. After i set up my home theater equipment it worked fine.A couple of hours later i went in to listen to some music and turned the reciever on.It turned itself off after like 2 seconds and the standby lite started flashing. is there anything i can do to fix this problem or am i screwed?
also i opened up the case and checked the internal fuse it was fine.
Username: Mccambley
BREEZY POINT, NY
Post Number: 195
Sounds like a crossed speaker wire were + and - wires are touching.
there are no speaker wires hooked up. i un hooked them when i opened the case and it still does it.
There are no wires hooked up. I unhooked them when i opened the case to check the fuse and it still does it.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 04, 2006 > Reciever shutting self off [ « Previous ] [ Next » ]
