Thread: HELP ON HOOKING UP MY DURABRAND HT-400 !!!!!!!!!!!!!! |
New member Username: Sportsfan27
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 08, 2006 - 11:52 am: |
I bought a durabrand ht-400 from a guy and i think everything was there, but i don't get how to hook up the wires because it has sections like subwoofer,left speaker,center speaker and etc.But on like the subwoofer it has blue,black,green and colors like that but those colors arent all under subwoofer so do i put them under the other sections. |
Bronze Member Username: Floyd_1977
Plainfield,
IL
Post Number: 33 Registered: May-06
| Posted on Thursday, June 08, 2006 - 03:50 pm: |
Unless someone here has that particular HTiB, you're not likely to get much help, as blue, black, green, etc. don't mean anything to us. I would try to find the manual for this HTiB, if it wasn't included. Typically, you only need to run one cable to your sub (marked "LFE in", "bypass crossover", etc.). |
Plainfield,
IL
Post Number: 34 Registered: May-06
| Posted on Thursday, June 08, 2006 - 03:53 pm: |
I should also mention that HTiB's sometimes have a special way of connecting speakers. Sometimes all speakers need to be connected to the sub, so you really need to get ahold of the manual if the connections are not clearly labeled. |
