Thread: Onkyo HTS 780 b |
New member Username: Captaintom
Post Number: 1 Registered: Jun-06
| Posted on Saturday, June 03, 2006 - 09:47 pm: |
Need some help setting up this system. Everything works and sounds good. Only trouble is I get no sound on a number a cable stations. Video is great on those stations. The cable system is Cablevision in central NJ. Station 8 and stations 30 thru 59 will not produce sound. A few others also but the 300 movies channels work fine. Anybody run into this before? Thanks. Capt Tom
Silver Member Username: John_s
Columbus,
Ohio
US
Post Number: 958 Registered: Feb-04
| Posted on Sunday, June 04, 2006 - 07:20 pm: |
Anybody run into this before? A few years ago I hooked up the S/PDIF coax digital audio output from the cable box to my receiver. There was no sound on any channel below 100. I was forced to use the analog audio outputs for the lower channels. |
Bronze Member Username: Mmastin
Colorado Springs,
CO
Post Number: 16 Registered: Oct-05
| Posted on Friday, June 16, 2006 - 04:54 pm: |
Bummer. You can probably put the Onkyo on TV mode and get a very good simulated surround sound with Analog connections. Fortunately I have Dish satellite and it sends digital signal thus I have an Optical connection. I have tried both Analog and Optical and honestly could not tell the difference. Probably could if they were side by side...maybe my ears are not sensitive enough. Anyhow, my point being that analog is decent. |
Post Number: 2 Registered: Jun-06
| Posted on Saturday, June 17, 2006 - 03:31 pm: |
Mark and John, thanks for your ideas. Turns out it was a combination of issues. The Cablevision box that I was hooked to was several years old. Switched to the newer box in my livingroom and everything works fine. Now I get great sound and picture on all channels. It was an analog/digital incompatibility problem (my son's words, who actually identified the problem). The problem I had with the DVD was my fault. I used video s cables to hook to the Cablevision box but used regular cables to hook up the DVD. Can't do that. Once I switch to all s Cable, the DVD works great. Support and the manual from Onkyo are lousy, but the system is great value. Love the sound. Capt Tom |
