Thread: Center Channel large or small |
New member Username: Bandwfan
Boston,
MA
Post Number: 2 Registered: Jun-06
| Posted on Friday, June 02, 2006 - 12:54 pm: |
Hello everyone! First post... Had a quick question I wanted to get some insight on. I just upgraded my reciever to the Sony STRDE-895. It has many more options than my old Sony, and so far, I love it. One question I have is this. One feature this receiver offers that my old one didn't is to choose the "size" of all my speakers, large vs. small. I understand this allows bass signals to be bypassed from any "small" speakers to go to the sub. The manual pretty much suggests keeping everything at "large". My front speakers are the old B&W 602's, my Center is the old CC6, and my surrounds are the new 603's. My question is this... Does the CC6 qualify as a "large" center channel. I typically have it on large, and everything sounds fine. I don't feel that the center is being overwhelmed or anything. When I change it to small, I can't even tell a difference, but I just want to make sure I am doing the right thing. It could come down to preference I guess. Any thoughts would be much appreciated. thanks! |
Silver Member Username: Usa2k4
Post Number: 168 Registered: Dec-04
| Posted on Friday, June 02, 2006 - 01:04 pm: |
Even if a speaker has 6.5" or bigger driver(s), if it can't go down to at least 40Hz, you need to set it to Small. |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 190 Registered: Jun-05
| Posted on Saturday, June 03, 2006 - 09:39 am: |
NBC what sub do you have? The B&W's are a nice set up, But they are book shelf size speakers that would be best set for small. You also have a sound level setting that when you run it from the set up menue it will send pink noise around the room so you can set the loudness for each speaker. |
Boston,
MA
Post Number: 3 Registered: Jun-06
| Posted on Saturday, June 03, 2006 - 11:17 am: |
My Sub is a Paradigm. 100 watt powered 12 inch sub. Sorry to be such an amateur, but what is "pink noise"? |
Silver Member Username: Praetorian
Post Number: 218 Registered: Dec-05
| Posted on Saturday, June 03, 2006 - 07:59 pm: |
It's a test signal that allows you to set the output level of each speaker to compensate for distances etc. Basically you want the same volume, during the test, to come out of each speaker. |
Boston,
MA
Post Number: 4 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 01:26 pm: |
Oh, ok, I didn't realize there was another name for "Test Tone". Thanks. That wouldn't help though, would it, since the pink noise is just that, noise. It is used to set the VOLUME of each speaker, not the bass adjustment, right? |
