Thread: My receiver and sub woofer |
Bronze Member Username: Deadhorse
Post Number: 13 Registered: May-06
| Posted on Friday, June 02, 2006 - 11:03 am: |
My receiver has two sub woofer outputs, a single line and a left/ring output. My sub only has a left/ring input and instructs that for a single line to use left channel input. I mistakenly bought a sub woofer cable that splits form a single to a double line. Should I run single line from the receiver into the left/right of the sub, vice versa or doesn't it really matter? |
Silver Member Username: Usa2k4
Post Number: 167 Registered: Dec-04
| Posted on Friday, June 02, 2006 - 11:52 am: |
Since your sub has left and right input jacks, you can run a single line from the receiver to both left and right inputs on the sub. On most subs, you'll notice a slight gain in loudness when connecting the them this way instead of using only 1 input jack as per the manual instructions. I think you've made a good mistake when you bought that cable, you do not need to buy a Y adapter after all . |
Post Number: 14 Registered: May-06
| Posted on Friday, June 02, 2006 - 11:55 am: |
Kevin, That's great news, I'm putting my system back together tomorrow so I'm sure I'll be back on here next week. Thanks. |
