Thread: Calibration |
Bronze Member Username: Hogwild
Post Number: 49 Registered: Aug-05
| Posted on Thursday, June 01, 2006 - 09:20 am: |
Everything is installed and powered up. Hooray. I watched a few scenes from the Matrix - gotta like that hall scene. Maybe I should've installed more soundproofing! Its great although I expect there is still some calibration to do (Audio and Video). There are so many choices. I would appreciate anyone sharing helpful calibration tips - especially if it happens to apply to my equipment. Sony VPLHS51 Denon 3806 Stewart Firehawk Panasonic S77 Paradigm Monitors HSU VTF3 MK2 HDMI connections |
Gold Member Username: Chitown
Post Number: 1053 Registered: Apr-05
| Posted on Thursday, June 01, 2006 - 11:15 am: |
Tip 1: Make sure you set the DVD player to output sound in digital and also progressive Tip 2: Play around until it sounds good to you Tip 2: Enjoy
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 186 Registered: Jun-05
| Posted on Thursday, June 01, 2006 - 02:09 pm: |
Great system but where's the HD, cable or dish. Video calibration is a must either a DVD like Digital Video Essentions or even better an ISF calibration (about $400). Go to Imagescienc efoundation.com to find a tech in your area. |
Post Number: 50 Registered: Aug-05
| Posted on Thursday, June 01, 2006 - 02:39 pm: |
Yeah, I'm still researching power conditioners. Next I'll be researching cable vs dish. Then a new gaming/theater computer. Thanks for the tips - I'll google them.
BREEZY POINT,
NY
Post Number: 188 Registered: Jun-05
| Posted on Thursday, June 01, 2006 - 09:44 pm: |
I'm sorry I should have given you the link http://www.imagingscience.com/the |
BREEZY POINT,
NY
Post Number: 189 Registered: Jun-05
| Posted on Thursday, June 01, 2006 - 09:50 pm: |
I wish there was a way to edit that last link http://www.imagingscience.com/ |
Silver Member Username: Praetorian
Post Number: 214 Registered: Dec-05
| Posted on Thursday, June 01, 2006 - 10:02 pm: |
Skip the "conditioner", just get a good power bar/strip (whatever) for surge protection. Focus in on cable/sat. With that TV your not living until you watch HD!  |
