Thread: Need help with how to get true surround from sky, PS2, TV with inexpensive all in one package |
New member Username: Robojim4000
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 31, 2006 - 07:25 pm: |
Hi there all. Basically, i am currently looking for an 'all in one' package (dvd player + speakers) so i can have my tv (and/or Sky), my PS2 and obviously my DVD player all playing true surround (by that i mean dolby digital). I understand that to get dolby digital (superior to dolby surround or pro logic II) i will have to use a digital optical cable. Would i have to use a digital optical cable for every separate thing? If so thats impossible as there isnt really any sub £500 all in one packages that do have 3 digital optical ins.....or am i missing the point here? |
Silver Member Username: John_s
Columbus,
Ohio
US
Post Number: 956 Registered: Feb-04
| Posted on Thursday, June 01, 2006 - 08:17 am: |
No, you are not missing the point. You do need to be able to handle the separate digital audio outs from your sources. All you need is an all-in-one unit that has one optical input. You can then get a TOSLink 3-way optical switcher. http://www.tvcables.co.uk/cgi-bin/tvcables/scan/ml=6/sp=rs4/se=Audio/se=Switch/s e=Box.html Cheers. |
Post Number: 3 Registered: May-06
| Posted on Thursday, June 01, 2006 - 03:24 pm: |
wow, thats brilliant and simple advice. And saves me money, cheers |
