Thread: HK AVR 340 PLEASE HELP |
New member Username: Sydney
Post Number: 1 Registered: May-06
| Posted on Sunday, May 28, 2006 - 07:54 am: |
I have just purchased a Harman Kardon AVR 340 system. I appreciate that it is 55 W 7.1 and 75 W stereo. I have two speakers attached however the volume coming out is less than my 20 year old small Sony system. Can somebody please explain if I have a system setup problem, or a system problem. Thanks in advance |
Bronze Member Username: Floyd_1977
Plainfield,
IL
Post Number: 13 Registered: May-06
| Posted on Sunday, May 28, 2006 - 08:00 am: |
Your post begs many questions. What source are you using, and how is that source connected to your receiver? Do you notice an increase in volume when you switch to the receiver's tuner? Are you saying that even at the max volume level, output is insufficient? Or are you falling into the trap of worrying about what the volume level reads on the receiver (which varies from brand to brand and even model to model of the same brand). |
Post Number: 2 Registered: May-06
| Posted on Sunday, May 28, 2006 - 08:21 am: |
I have tried two devices, 1 is my dvd player - using component (red / white connectors) and the other is my ipod via the 'bridge connection'. (I will try the tuner in the morning / my daughter is asleep No I am not referring to the numbers on the dial. But to how much volume I have the speakers output. I have a hitachi plama which I think has 10W speakers - they seem to fill the room considerably better. By the way the speakers are B&W CM4.
Plainfield,
IL
Post Number: 14 Registered: May-06
| Posted on Sunday, May 28, 2006 - 03:38 pm: |
You mean "composite", not "component". I would strongly recommend using a digital connection between your DVD player and receiver. If you are using analog, keep in mind that the audio settings in both your DVD player and receiver will have an affect on the sound. I'd especially check for any sound field modes you may have activiated. For instance, you want your receiver in Stereo mode. Let me ask again. Are you turning your receiver's volume up to max and still not getting adequate volume? |
Bronze Member Username: Noya83
Portland,
Oregon
Post Number: 16 Registered: May-06
| Posted on Monday, June 05, 2006 - 02:24 am: |
Les, The red/white are the lowest quality connection you cna use. Buy a 'digital coaxial' audio cable and hook it to your DVD players 'Digital output' and plug it into your receivers DVD player 'digital coaxial' connection. It looks similar to the red/white stereo analog cables your using but it is usually orange or black in color. Make sure to go into your DVD player menu and set the audio to 'digital'. -Michael |
