Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Bose lifestyle Problem
Author Thread: Bose lifestyle Problem
Username: Daniscp
I i'm new around here and would appreciate if anyone could help me. I have a problem with my system. When I use the system in the "AUX" mode the sound is perfect but when I change it to "TV" mode it's much lower and I need to have it on max volume in order to hear anything at all. This happened this week so I would appreciate if anyone could help me. Thanks in advance.
Username: Downunder
G'day Author,
I'new here too. Make sure you volume from your source is turned up. E.g.- cable tv.
Also check if there is another audio output on your source(red and white plugs). As this may be a fixed output.
Thios also works in reverse. i.e. If your AUX source has a volume adjustment, turn it down.
Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Bose lifestyle Problem [ « Previous ] [ Next » ]
