Thread: Paradigm CC-470 as l/r channel speaker? |
New member Username: Kdreuther
Post Number: 1 Registered: May-06
| Posted on Sunday, May 21, 2006 - 07:44 pm: |
My speaker store recommended to use 3 Paradigm CC-470 as left, center and right channel speakers, all arranged at the same height. Rear speakers would be in-ceiling Paradigm SA-15R. Wondering what you guys think about this configuration. Thanks, Dieter |
Post Number: 8123 Registered: Dec-03
| Posted on Tuesday, May 23, 2006 - 12:43 am: |
Why would they recommend that? Did they give you a reason? It will work...I just find it odd. |
Post Number: 2 Registered: May-06
| Posted on Tuesday, May 23, 2006 - 12:59 am: |
We are planning a new cabinet/shelving system at the wall of the TV and having the the 3 speakers in one row would work pretty good for our design. The sales consultant also believes having 3 identical systems has a certain advantage. The 3 CC-470 would be positioned horizontally on the same height, below the TV.
Gold Member Username: Gavincumm
New York
Post Number: 1155 Registered: Feb-05
| Posted on Tuesday, May 23, 2006 - 03:34 pm: |
you would want the left and right to be vertical if at all possible. |
Bronze Member Username: Willieman
PR
Post Number: 20 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 02:37 pm: |
