Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 20, 2006 > Wall surround mounts
Author Thread: Wall surround mounts
Username: Hogwild
Post Number: 40
I needed to mount some 16 lb surrounds near the wall/ceiling.
I couldn't find a mount that supported the speaker from underneath (as the manufacturer recommended) and still maintain headroom to walk under the speaker.
In my solution I used Vogel VBL100's because of their load rating and metal construction. I welded some angle iron and plate to support the speaker from below. A few screws through the base prevent the speaker from sliding off when angled.
It worked. They look great too. If you're looking for speaker mounts - have a look at the Vogels.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 20, 2006 > Wall surround mounts [ « Previous ] [ Next » ]
