Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 20, 2006 > Pleading for the best options.
Author Thread: Pleading for the best options.
Username: Liptoger
Hi all, I was hoping someone would be able to help me. I have just bought a Pioneer recorder, thus disposing of my VCR and DVD player.The problem is that i can't seem to get true Dolby Digital or DTS when watching dvd's. The recorders settings are all on and i am not sure where i have gone wrong. I am also not sure of what needs to go into the TV's Media Centre and what goes into the receiver. Does anyone have an idea on the optimal settings for this type of setup? My components list follows. Any feedback would be graciously received. Thankyou.
Pioneer Plasma 50"
Pioneer DVD Recorder DVR-630H-S
Sony Receiver STR-DE685
Teac Set Top Box DV-B800
Username: Chitown
Post Number: 973
Try this
http://www.ce.org/connections_application/CEA_Connections_Guide_Final_v2.swf
Username: Liptoger
Thanks so much Stof. I have connected via the guide and everything seems tip top. Only problem is my receiver doesn't seem to pick up the OPTICAL connection from the DVR but when i hook up my old DVD player via COAXIAL it works. The DVR doesn't have a COAXIAL connection so therefore i think i need a converter box to run the OPTICAL from the DVR and connect to the COAXIAL in the receiver.If you have any other options i'd love to hear them. Thanks again, my friend. :-)
Username: Chitown
Post Number: 977
I'm not sure about settins on that particular model of receiver, but make sure that the input for DVD connection on the receiver is configured for that particular Optical port. In other words it has to know that you are running your DVD output through that particular connection.
Username: Usa2k4
Post Number: 136
Yep, you'll need to run input assignment as Stof said to assign coaxial or optical for the input. FYI, you can get 1 of the converters like those shown here: http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3 in case you'll ever need 1 in the future. :-)
Username: Usa2k4
Post Number: 137
Sorry for the bad link. Anyway, search for optical to coaxial or coaxial to optical if you want to see their pics and the info.
Username: Liptoger
Thanks for your help guys. I have spent time scouring many forums and have finally come up with the solution. Apparently on the receiver i have i need to assign the optical to Video 2(which is actually a 2nd function so i have to press 2 keys on remote to get it). It's an odd setup, i'd assume that the optical would still be connected to the DVD/LD setting but that just belongs to the coaxial. Thanks again for your help and i hope this info helps anyone else who has the same receiver as i have.Cheers :-)
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 20, 2006 > Pleading for the best options. [ « Previous ] [ Next » ]
