Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through June 05, 2006 > Looking for a compact/quality system ...
Author Thread: Looking for a compact/quality system that works on 220 volts
Username: Kelenbalint
Can someone recommend a compact quality home theater system (such as Paradigm or Orb) with a powered subwoofer that runs on European power (220 volts)?
Username: Project6
Post Number: 7908
Both are well known, reputable and great speakers. You can't go wrong with either choice. Your powered subwoofer does not have to be the same brand as your main speakers. Take a look at HSU subs. They have guidance on switching voltage requirements
http://www.hsuresearch.com/forum/showthread.php?t=773
Username: Willieman
PR
Post Number: 24
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through June 05, 2006 > Looking for a compact/quality system ... [ « Previous ] [ Next » ]
