Thread: More holes than a Do-nut shoppe |
New member Username: Tangled_mess
Post Number: 1 Registered: Feb-06
| Posted on Friday, May 05, 2006 - 08:24 pm: |
I beg for your expert advice on how to connect this stuff. I've read all the technical literature I can stand and I need somebody to 'splain this to me in sub-rookie terms. I'm trying to connect the following: Samsung HL-R5067W HDTV with: Cable In, Antenna 2 In, DVI In audio L/R, PC in audio L/R, AV In 1 and AV In 2 both with S-video, video, audio L/R, D-Net IEEE1394)400MPEG, HDMI/DVI in, PC in, Component 1 and Component 2 each with Y-Pb-Pr and audio L/R, G-LINK, Anynet, Digital Audio Out (Optical) Kenwood VRS-6100 receiver with: Optical Video, Coaxial DVD, Video (Record out, video out, play in, video in),DVD video (Y-R-W), Aux In L/R, Monitor, cable LGXBR446 DVD/VCRcombo with: Ant In, Ant Out, Optical audio out, S-video out, AV 1 In and DVD/VCR Output AV Out-both with(Y-R-W), Component Progressive Scan Video Out with Audio out L/R, Coaxial Scientific Atlanta (Time Warner) Explorer 3250HD CATV Converter with: Optical Audio Out, DVI, S-Video Out, IR, HDTV (Y-Pr-PB), Audio out L/R. I realize I may have over simplified this for most(all)of you, but there are more holes in this thing than in a Do-nut shoppe. I beg your help with plugging which hole with what so that I can get the best use of this equipment. Thank you. I remain, Tangled-Mess |
