Thread: How do I connect the Velodyne DLS-4000R Sub-Woofer |
New member Username: 1lakerfan
Post Number: 4 Registered: Apr-06
| Posted on Friday, April 28, 2006 - 08:58 pm: |
It comes with a Subwoofer interconnect cable and has a Y-adpter |
Post Number: 7692 Registered: Dec-03
| Posted on Friday, April 28, 2006 - 09:02 pm: |
What receiver will you be using? Check your receiver's manual and see the section about connecting the subwoofer. Also, check the subwoofer manual on how to connect your subwoofer to a receiver. |
Post Number: 7693 Registered: Dec-03
| Posted on Friday, April 28, 2006 - 09:05 pm: |
If your receiver has a subwoofer output or an "LFE" output you connect this to the "LFE" input of your Velodyne, using that subwoofer interconnect cable. |
Post Number: 5 Registered: Apr-06
| Posted on Friday, April 28, 2006 - 09:16 pm: |
Yamaha RX-V995 |
Post Number: 7701 Registered: Dec-03
| Posted on Friday, April 28, 2006 - 09:33 pm: |
Look in page 26 of your Yamaha manual. This will show you how to connect your Velodyne. You only need the subwoofer cable. You do not need to use the Y adapter. |
Post Number: 6 Registered: Apr-06
| Posted on Saturday, April 29, 2006 - 03:59 pm: |
I plugged one of the cable to the LFE input on the subwoofer and on the other end I was going to plug in to the receiver where it said "subwoofer" but it would'nt fit. |
Post Number: 7717 Registered: Dec-03
| Posted on Saturday, April 29, 2006 - 06:01 pm: |
That is odd...the Subwoofer output of that Yamaha is RCA. The cable for you Velodyne subwoofer should not have different ends, just RCA jacks...does it? If the output jack on your Yamaha and the input jack on your Velodyne are the same, they should fit. If they don't, take a closer look at your subwoofer cable. |
Post Number: 7 Registered: Apr-06
| Posted on Saturday, April 29, 2006 - 06:25 pm: |
The cable is the same on both ends and what do you mean when you say the Subwoofer output of that Yamaha is RCA. |
Post Number: 7721 Registered: Dec-03
| Posted on Saturday, April 29, 2006 - 06:39 pm: |
It is a standard RCA jack. It should look the same as the RCA jack you are using on the back of the Velodyne. |
Post Number: 7755 Registered: Dec-03
| Posted on Sunday, April 30, 2006 - 08:49 pm: |
Did you work this out? |
New member Username: Nfminstaller
| Posted on Monday, May 01, 2006 - 05:00 pm: |
The Y adapter is to plug into the R/W input on the sub. This allows you to use the crossover setting on your sub (if you are so inclined). You plug the cable into the sub out/preout of the reciever, into the Y, and then both into the sub. |
