Thread: Sony DAV-SC8 System |
Bronze Member Username: Bobha
Post Number: 26 Registered: Feb-06
| Posted on Sunday, April 23, 2006 - 08:31 am: |
Hi Guys, This from Fixya: http://www.fixya.com/problems-solutions/t103265,p225302/Sony-DAV-SC8-System.aspx Will appriciate any help. Flashing standby message. Most functions work fine i.e sound for the T.V but when you push the power button to standby the system just flashes 'standby'. Also if you try to switch to DVD mode either by using the function button or inserting a DVD the system just goes blank with nothing lit. Only way to get it working in both cases so I can get sound for my T.V is to switch off then on at the socket. Any help would be great. |
Bronze Member Username: Willieman
PR
Post Number: 27 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 02:51 pm: |
New member Username: Robert341
Post Number: 1 Registered: Jul-06
| Posted on Tuesday, July 18, 2006 - 08:08 am: |
Re Flashing standby message. Most functions work fine i.e sound for the T.V but when you push the power button to standby the system just flashes 'standby'. Also if you try to switch to DVD mode either by using the function button or inserting a DVD the system just goes blank with nothing lit. Only way to get it working in both cases so I can get sound for my T.V is to switch off then on at the socket. I'm having the same problem, again any help out there? |
Post Number: 2 Registered: Jul-06
| Posted on Tuesday, July 18, 2006 - 08:11 am: |
DOES ANYONE KNOW THE SKY 3 DIGIT REMOTE CONTROL CODE FOR THE SONY DAV-SC8? THANKS, STEVE |
