Thread: Onkyo HT-S760 Home Theater |
Bronze Member Username: Silas92
Post Number: 11 Registered: Apr-06
| Posted on Saturday, April 08, 2006 - 06:44 pm: |
Is the Onkyo HT-S760 Home Theater better than the yamaha yht-360? |
Post Number: 7374 Registered: Dec-03
| Posted on Saturday, April 08, 2006 - 07:46 pm: |
Some think so and some do not. It really depends on you and what you think is better. Go out there, listen and make a determination. |
New member Username: Mmastin
Colorado Springs,
CO
Post Number: 6 Registered: Oct-05
| Posted on Wednesday, April 19, 2006 - 01:41 pm: |
Sorry for the late post, but I am not on this forum often. I have the Onkyo HT-s780. It rocks. I think the yamaha is very much a budget time offering where as the Onkyo is price wise, but not performance wise. If they both sound good to you then check out connections and numbers to see which fits your needs. |
