Thread: Yamaha yht-360 |
New member Username: Silas92
Post Number: 1 Registered: Apr-06
| Posted on Friday, April 07, 2006 - 08:29 pm: |
Hi guys Im about to get a Yamaha yht-360, but i heard the sub isnt too good!!! Its passive so it is to be expected, but does any 1 have any subs they can reccomend to me for $200 or under, I like the Jbl E150P Black Northridge E Series 10" Sub, I think that would go well, do u guys have any better suggestions? thanx |
Post Number: 7363 Registered: Dec-03
| Posted on Friday, April 07, 2006 - 09:02 pm: |
The best thing to do is to just set it up and determine for yourself if it is a good enough set-up. Listen to it first, and if you find it lacking or not up to your liking, then determine if it is the sub that's the problem or something else. |
Post Number: 2 Registered: Apr-06
| Posted on Friday, April 07, 2006 - 10:22 pm: |
Thanx, but if it does turn out to be pretty bad could u recomend me a sub to upgrade it with? |
Post Number: 7367 Registered: Dec-03
| Posted on Saturday, April 08, 2006 - 03:51 am: |
You may want to replace the whole speaker set-up, not just the sub. However, if you are planning to replace just the sub, the JBL should sound better. Then there's HSU and SVS. |
Post Number: 5 Registered: Apr-06
| Posted on Saturday, April 08, 2006 - 09:14 am: |
Thanx, so are the speakers on that setup not too good or something? do u think im better off building my own say: Athena micra 6 and a panny xr55? |
Post Number: 7368 Registered: Dec-03
| Posted on Saturday, April 08, 2006 - 10:26 am: |
Yes, you will be better off building your system. The Athena Micra 6 are excellent speakers, I just don't know about the XR-55 as I have not tried it. |
Post Number: 6 Registered: Apr-06
| Posted on Saturday, April 08, 2006 - 01:31 pm: |
Hey thanx Berny, is there any reciver that u would reccomend, thats cheap? as I am a teenager and on a low budget, thanx again |
Post Number: 7 Registered: Apr-06
| Posted on Saturday, April 08, 2006 - 01:48 pm: |
I have just been to Best Buy to test the yht-360. I only got to try it in fm radio mode and only the front two speakers. I thought personaly it was great. I looked at the speakers and they looked pretty good quality and the sound was good quality. The only thing i didn't like was the sub as i stated in my original post, i couldn't hear it!!! I dont no wether it was the main speakers producing the bass or the actual sub? But overall it was excellent especially the reciever. I wanted to test the athena micra 6's but they did not have them. A well i think i might stick to the yht-360 and just upgrade the sub when i get some more money!!!lol |
Post Number: 9 Registered: Apr-06
| Posted on Saturday, April 08, 2006 - 02:28 pm: |
Oh yeh one more thing if i buy some 12 or 14 gauge speaker wire will it improve the sound from the original 24 gauge or is that a myth? |
Post Number: 7373 Registered: Dec-03
| Posted on Saturday, April 08, 2006 - 07:44 pm: |
If you really want improved sound, change the speakers or, like I wrote before, buy a separate reciever and speakers. Using a 14 gauge speaker wire is better, but I doubt that you will any significant improvement on that HTIB. Do not expect too much out of an entry level system and think you will get signifcant improvements by spending too much on tweaks. |
Bronze Member Username: Silas92
Post Number: 12 Registered: Apr-06
| Posted on Saturday, April 08, 2006 - 09:57 pm: |
Ok I think all make my own system!!! how does this sound: Athena micra 6 and a panny xr 55? |
Post Number: 7376 Registered: Dec-03
| Posted on Saturday, April 08, 2006 - 11:47 pm: |
I like the Athena Micra 6 and believe that they are great speakers. I cannot pass judgement on the Panasonic as I have not heard them. |
Post Number: 13 Registered: Apr-06
| Posted on Sunday, April 09, 2006 - 09:31 am: |
Thanx guys for all your inputs, ive decide to go with the athena micra 6's and either a panny xr55 or onkyo or yamaha recievr!!! |
Post Number: 14 Registered: Apr-06
| Posted on Sunday, April 09, 2006 - 01:11 pm: |
I found a great deal: Infinity Total Solutions TSS-450 - Home theater speaker system (which has great reviews) and a panny xr55 (great reviews also) all comes upto $420 |
Post Number: 7380 Registered: Dec-03
| Posted on Sunday, April 09, 2006 - 07:39 pm: |
Sounds like a deal! |
