Thread: Koss 5192 |
New member Username: Bdkexcell
Post Number: 1 Registered: Mar-06
| Posted on Thursday, March 30, 2006 - 07:13 pm: |
hey for the 6.1 ks5192 the back speaker doesnt work for cd's, and the only movies ive played it on are movies with 5.1, and the back speaker has not been used im curious tho, should the back speaker not work for 5.1 or cd's? also on the lcd screen when it shows all 6 speakers the back one is in red while the other are blue thanks for any help |
New member Username: Sim_89
Post Number: 1 Registered: May-06
| Posted on Tuesday, May 30, 2006 - 01:28 am: |
hey AK the rear channel only works on 6.1 dvds not regular dvds or cds and on the LCD display, the rear channel will be blue when 6.1 dvds are played The problem im having is getting the SD card reader to work, if you can help thx. |
New member Username: Techwizz
Post Number: 2 Registered: Jun-06
| Posted on Friday, June 09, 2006 - 04:47 am: |
Guys, if you have the time to open up your koss system and take a picture of the power supply module since my Koss KS4190 bugged down. Root cause is a PWM IC burnt up leaving no trace of part number on it. That's why I cannot buy a replacement part for it since I do not have it's part number. Anyone who would be so kind, please email the pic to michaelaneglo_usc11@yahoo.com. Thanks in advance. |
