Thread: Recommendations |
New member Username: Jwilhite
Post Number: 1 Registered: Mar-06
| Posted on Tuesday, March 14, 2006 - 08:22 pm: |
I need help on a reliable HomeTheater system?? I have two companies in mind Bose and Onkyo. What company should I choose?? Thank you for your help. |
Post Number: 6973 Registered: Dec-03
| Posted on Tuesday, March 14, 2006 - 09:41 pm: |
Listen to both and make a decision based on what you think sound better. Unless you don't have access to any at all and those are the only 2 options...then my personal preference will be Onkyo. Yours could very well go the other way, and there is nothing wrong with that. Don't let other people tell you otherwise, even from self proclaimed "audiophile experts", they are the worst kind. Listening for yourself will be the most important thing to do when buying audio equipment. |
Bronze Member Username: Jethro
Lansing,
Mi
Post Number: 36 Registered: Jan-06
| Posted on Tuesday, March 14, 2006 - 11:50 pm: |
ya listen is best start as these system generally line the isle in stores like best buy and circuit city. i "listened" for myself and i liked the yamaha and lg systems best, bought the lg system. its pretty sweet in my bedroom, has all skinny towers looks good sounds good. the dvd/receiver combo on this unit however is completely reliable, is also noisy for some reason. i have reason to believe that the yamaha and onkyo may be better in this department of reliability which is an issue with this stuff it in the box approach to home theater. don't know if i steered u into the right direction or worsened the situation, but like berny states, these htib systems are generally easy access to listen to for urself. one thing i would like u to do just for ur own satisfaction as i wished i had done bfore i purchased mine.. play at a low volume and listen to the dvd/receiver component itself and see if u hear any noises coming from it. at very low volumes i.e. dvd b4 bedtime if u will, u will want a quiet performing receiver/dvd combo, sorry for the ramble had a few beers cheers -jeff |
Post Number: 6997 Registered: Dec-03
| Posted on Wednesday, March 15, 2006 - 12:07 am: |
No laws against posting and drinking...LOL |
Post Number: 2 Registered: Mar-06
| Posted on Wednesday, March 15, 2006 - 01:36 pm: |
Thanks guys! I will have to go to Circuitcity this weekend and listen to my two choices. Again thank you! Jon |
New member Username: Oddsockjr
Post Number: 9 Registered: Mar-06
| Posted on Thursday, March 16, 2006 - 02:24 pm: |
Just be wary...make sure that you can return it. We have the Onkyo HTS-780 at my store. In my opinion, it's the best sounding system under $500. But in our huge open floor, it sounds terrible. The woofer is shot, and barely rumbles, the left speaker is completely out, and they're all lined up on top of a TV, so you can't even feel the surround sound part of it all. From what I know of circuit city, their displays end up about the same as ours. They put them out on the floor, line up all the speakers in a big open room, and then everyone gets to play with them so the settings end up all messed up. You definitely need to listen and play with them. But make sure, if you're not satisfied, that you'll be able to return or exchange. |
Bronze Member Username: Jwilhite
Post Number: 14 Registered: Mar-06
| Posted on Thursday, March 16, 2006 - 09:02 pm: |
Are there any other places you recommend? Jon |
Post Number: 7079 Registered: Dec-03
| Posted on Friday, March 17, 2006 - 02:17 am: |
What is available in your area? |
Post Number: 16 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 03:55 pm: |
There is The Ultimate Electronics Store, Bestbuy,Circuit City, Radio Shack, UMM I think thats it. Jon |
Post Number: 7097 Registered: Dec-03
| Posted on Friday, March 17, 2006 - 07:54 pm: |
Look in the yellow pages and seek out some independent audio/video dealer. |
