Home > Message Board > Home Theater > Home Theater Computers > 9A60 transcoder Sony KV-30HS420
Author Thread: 9A60 transcoder Sony KV-30HS420
Username: Tooterfish
hello gang.
KV-30HS420 CRT HDTV
GeForceFX 5900 video card
WinXP SP2
Audio Authority's 9A60 transcoder
PStrip 3.63
I've got my PC monitor hooked up to the VGA out on the video card, the TV hooked to the PC via DVI out->DVI to VGA converter->VGA cable->9A60->component cable->HDTV.
The regular monitor works fine, here's the problem, when I shut the PC off and then back on I see the Windows loading screen (on the TV), as soon as it's past that the screen goes black (the PC monitor still works fine though). AM I missing something that's needed to get the screen to stay on after that?
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater Computers > 9A60 transcoder Sony KV-30HS420 [ « Previous ] [ Next » ]
