Thread: LG home theater?? |
New member Username: Jkpaulson
Post Number: 1 Registered: Feb-06
| Posted on Tuesday, February 21, 2006 - 12:01 pm: |
Does anyone know anything about the LG LHY-518 theater in a box? I can't find any reviews, I am wondering if it is new to the market. http://www.bestbuy.com/site/olspage.jsp?skuId=7120037&type=product&id=1109234042 659
Silver Member Username: John_s
Columbus,
Ohio
US
Post Number: 739 Registered: Feb-04
| Posted on Tuesday, February 21, 2006 - 03:33 pm: |
Don't know about this model, but mucho probs with an LG English system: http://forum.ecoustics.com/bbs/messages/3/154962.html
Bronze Member Username: Jethro
Lansing,
Mi
Post Number: 38 Registered: Jan-06
| Posted on Wednesday, March 15, 2006 - 12:07 am: |
i have that system in my bedroom, it sounds fine, its just not very durable. towers easily knocked over, had a problem with what seems to be a short in one of the amp sections of the combo receiver/dvd or maybe just the wiring. but i adjusted the system a bit, and as long as i don't touch it, hehe, its good to go. once u got ur so8und coming from all 5 speakers and ur sub, just leave the picky sob alone. sounds good, receiver/dvd combo makes loud noise while playin, like dvd is spinnin really friggin fast. -jeff |
Post Number: 6998 Registered: Dec-03
| Posted on Wednesday, March 15, 2006 - 12:10 am: |
LG used to be a brand called Goldstar. Known for bargain electronics and other cheap stuff. They didn't last too long because of quality control issues. A name change did not change anything at all, I suppose. |
New member Username: Atfree
Hendersonville,
NC
Post Number: 1 Registered: Apr-06
| Posted on Thursday, April 27, 2006 - 10:46 am: |
I've had this system for about a month. Wonderful system. 1200 watts, DVD burner, VHS, radio tuner, and memory card reader all in one. Here's my take on the other posts: towers easily knocked over? No way, unless you're tag-team wrestling. I've got 2 kids, 3 cats, and a dog, and they haven't even come close to knocking them over. As for LG being Goldstar at one time, this is true. But I did a lot of research before I bought and LG has made great strides towards changing the way they do business. As for the different DVD formats, this unit, I believe, supports all current formats (DVD-R, DVD-RW, etc). I've burned both copies of old VHS tapes and shows saved on my TIVO unit, and it works flawlessly. Finally, when I was doing my research on HTIB units, I got really sick of all the "audiophiles" on these forums knocking HTIB units continually. Yes, I'm sure you can piece together a component system that is of higher quality, but the average person (who makes up 90% of the consumers out there) are not going to take the time to research and then purchase all the different components. It's simply not convenient, nor can the average person really tell the difference between the sound quality. So, "audiophiles" why don't you either provide quality advice on all spectrums of home theater systems, rather than simply bashing HTIB units, most of which you've never even given a chance! Does "Car and Driver" or "Road and Track" ONLY review BMW's and Mercedes? NO! They OBJECTIVELY review all automobiles. They don't simply say 'The new Hyundai stinks because all Hyundai's stink' without even actually driving it. |
Post Number: 7661 Registered: Dec-03
| Posted on Thursday, April 27, 2006 - 05:09 pm: |
1200 watts? You are deluding yourself! Yes LG has indeed changed the way they do business if you actually believe that your system is pumping out 1200 watts. |
Hendersonville,
NC
Post Number: 2 Registered: Apr-06
| Posted on Thursday, April 27, 2006 - 08:59 pm: |
Berny, Not to cast accusations, but you're apparently one of the conceited "audiophiles" I referenced in my e-mail! The system is rated at 1200 watts, and the volume control goes to "40". I live in a 4000 sq ft house, and if I get it above "20", you can hear the roar 4 houses down the block! More than suitable for us ignorant non-audiophiles. |
Post Number: 7665 Registered: Dec-03
| Posted on Thursday, April 27, 2006 - 11:38 pm: |
Alex, Cast all the accusations that you want. But indeed, your ignorance is very apparent if actually believe that your system is pumping out 1200 watts.
Hendersonville,
NC
Post Number: 3 Registered: Apr-06
| Posted on Friday, April 28, 2006 - 09:02 am: |
And why shouldn't I believe it? |
Post Number: 7673 Registered: Dec-03
| Posted on Friday, April 28, 2006 - 10:39 am: |
Here is what is written in the defintion of terms about your oh so wonderfully powerful 1200 watt system that you bought at Best Buy or maybe Circuit City(doesn't matter really). Heck, I'll just cut and paste it for you: "Total System Power The total amount of peak power an amplifier is capable of producing as a brief burst. For example, a system that is capable of producing 100 watts of peak power for each of the 6 speaker outputs would have a total system power rating of 600 watts. "Total System Power" is usually not as helpful a measurement as "RMS Power", which measures the amount of continuous power that an amplifier produces." Do you want me to translate it for you? Your 1200 watts of system power is designed to impress ignorants like yourself. Is it okay if I use that...after all you did describe yourself as such? The power is peak output burst and that term has never been defined in any standard, but it is most often used by adding together the rated burst output of all the channels in a system together. Simply put, your precious system has been rated to dole out a maximum burst of 180 watts per channel. What LG did, towards making "great strides in the way they do business", was add all of those outputs together and came up with 1200 watts. Nothing illegal about that claim, however misleading it can be. Do you know what a peak burst is? It means that it does not last too long. It could last for a few seconds, even less. The trouble with these type of reading is that you can manipulate the result to show a higher power rating than the system can actually sustain. They can actually write just the measurement when there was that one instant that the output reached that rating. They were not lying when they claimed 180 watts, they just don't tell you that the system really cannot maintain that. You have to be smart enough to deduce that on your own. Or maybe, they were counting on the average consumer not to take the time to do their research. One reason why so many consumers get suckered, such as yourself, is because they chose to remain ignorant and did not take the time to educate themselves and do said research. I doubt however, that it is about 90%. I think you under estimate a lot of consumers or did you just come up with that number? Don't get mad now....these things were not meant to mislead you, they were just counting on you not do your research, even though you made claims to the contrary. Obviously you were impressed by their claims by the way you proclaim your system to rock 4 houses down. Hmm, they don't happen to be doll houses, are they? You really should start reading the fine print, it is very apparent that you're a sucker. Oh and I have never made a claim to be an "audiophile". I just do more research than you did You really shouldn't burst on this scene like a total noobie coming in with nothing more than an impassioned "accusations" and getting sick of all the audiophiles who are knocking HTIBs continually. If you take the time to do research, you will find that most of us here try to steer them from products that may have potential problems. Some of us have learned from our mistakes and most of us started with simple systems and usually not that great because it was all we could afford at the time. Some benefit from our experience and hopefully not make the same mistakes that we did, and some take it the wrong way and start flailing angrily because they think we knock their system down. This is what these forums are for. You ask...we try to answer, and sometimes people don't like the answers, such is life. If you cannot handle such things, that's too bad, life goes on, and you just get sick. |
New member Username: Primus2112
Post Number: 7 Registered: Apr-06
| Posted on Sunday, May 07, 2006 - 08:38 pm: |
Wow Berny! Awesome response! Not to dis Alex but just all the info that electronic companies mislead us with marketing I guess. Anyways I think overall LG Electronics is kind a shabby... My brother had a DVD player a year ago and we had to return it and they sent a newer model witch conked out too. I read an article about 6 months ago on there expansion and I am not sure how they are doing that... washers dryers refridgerators etc etc... maybe some day Pioneer, Infinity or maybe even Bose will come out with some microwaves and fridges too! |
Post Number: 7902 Registered: Dec-03
| Posted on Sunday, May 07, 2006 - 10:14 pm: |
I love trolls like Alex...they make things so much livelier Dis away, Rob, I doubt that he had respect in mind when he came trolling in.
Columbus,
Ohio
US
Post Number: 906 Registered: Feb-04
| Posted on Monday, May 08, 2006 - 08:33 am: |
How about a Mark Levinson toaster?
Post Number: 7914 Registered: Dec-03
| Posted on Monday, May 08, 2006 - 05:11 pm: |
Gotta love that power cord |
Post Number: 8 Registered: Apr-06
| Posted on Monday, May 08, 2006 - 06:23 pm: |
LMAO!!! |
Post Number: 7941 Registered: Dec-03
| Posted on Wednesday, May 10, 2006 - 12:41 am: |
He sells LG equipment or the Mark Levinson toaster? |
New member Username: Jav1204
Chihuahua,
Chihuahua
Mexico
Post Number: 1 Registered: Jul-06
| Posted on Friday, July 14, 2006 - 01:51 pm: |
The conversational audio is not working properly into the LG dvd home theater, the background audio is fine but not the other one, what can I do to fix this problem up? |
