Thread: New Comer, need suggestion on the first system |
New member Username: Minimax
Post Number: 1 Registered: Feb-06
| Posted on Sunday, February 19, 2006 - 03:04 pm: |
After using my headphone (Senheisser580) for more than two years, I decided to listen to music in the air. Room space is about 14 X 10 (feet). Only for music, (85% of classical with rest for Jazz) I haven't got anything yet. Previously I use a mini shelf system, a headphone amp with my headphone. Budget is no more than $800. If that is tight, I can waive source for a while. I am looking at amp and speakers now. I found HK3480 is within my budget. Not sure about speakers, but I think bookshelf ones are fine. Any suggestion?
Post Number: 6122 Registered: Dec-03
| Posted on Monday, February 20, 2006 - 07:28 pm: |
Tough call. If you have been listening to headphones for a while, you will have a difficult time trying to adjust to regular speakers. What is available in your area? If you are willing to do the internet route, check out Axiom Audio M3 book shelf speakers or the M22. There have been rave reviews about the Alegria Audio Ling and the Alegria Audio Emma. Definitely worth a look. http://www.us.alegriaaudio.com/Emma.htm |
