Thread: Starting from Scratch...would like ideas and opinions |
New member Username: Patenl
Post Number: 1 Registered: Feb-06
| Posted on Friday, February 17, 2006 - 09:33 pm: |
Hi there, Been searching the web for months to get ideas on a perfect home theatre room and too bad I found this site only tonight. Anyways I have a 13'X 18' basement room that I am turning into a theatre room....I want your advice on what material to use for insulation, carpet on floor, Drop-ceiling tiles, cabinet for components in wall...also advice on LCD or PLasma or even a CRT 42" to 55". (will not be putting a projector) Hopefully someone would have pictures of their projects from start to finish. Just to give an idea...my room will have 2 exterior walls, 1 wall sharing the bedroom and the other wall sharing the shop (furnace, freezer etc..) I will have 1 door to enter the room going down 4 stairs (I have a 4 level side-split) and another door to the shop. I am planning on putting the TV on the shop wall... Budget is tight but all the walls or open so might as well do it right the first time. my email is patenl@gmail.com thanks Luc
Post Number: 5955 Registered: Dec-03
| Posted on Friday, February 17, 2006 - 10:05 pm: |
There some projects on this area of the forum. You can search for some ideas there. Budget is improtant for making recommendations. http://forum.ecoustics.com/bbs/messages/3/197718.html |
Post Number: 2 Registered: Feb-06
| Posted on Saturday, February 18, 2006 - 07:08 am: |
Hi Berny, As far as budget...it is tight but I am going with the flow.... I am doing the work myself so lets say for now $2500 Canadian for material...everything for walls (walls already framed so just insulation and drywall) , wiring A/V, hydro, ceiling, lights and floor. thanks again. Luc
