Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 23, 2006 > Wiring up reciever to Tv help..
Author Thread: Wiring up reciever to Tv help..
Username: Lopro
im goin to pick up a projection tv this week and i was wondering what wires would give me the best sound to my reciever..right now on my old tv i have audio out from the tv to audio in to the reciver with rca cables.any suggestions
Username: Project6
Post Number: 5926
Read on
http://www.audioholics.com/techtips/audioprinciples/cables.htm
Username: Lopro
do i just use audio cables output tv to input reciever?
Username: Lopro
also when hookin up a dvd player do i plug it in the Tv or do i have plug it in the reciever?
Username: Project6
Post Number: 5984
Yes, use the audio output of your tv and connect it to the receiver.
The DVD player's audio output goes to the receiver (optical,digital or analog).
The DVD player's video output connects to the TV's video input.
Username: Lopro
Post Number: 9
so i can do s -video from dvd to tv.then audio out from tv to reciver?
Username: Project6
Post Number: 6022
yes
Username: Lopro
Post Number: 11
is there a difference if i connecect audio out from tv to audio in reciever with a dvd player OR audio out from dvd player to reciever?
Username: Project6
Post Number: 6141
Depends on the output of your DVD player.
If you are using the digital output from your DVD player...connect it directly to the receiver.
If you want to hear the audio on your TV from your DVD player without turning on the receiver, connect the analog (L/R) output of your DVD player to the TV's audio inputs.
Username: Lopro
Post Number: 12
on my satelite reciever i have a connection sayin s/pdif should i use that to connect audio to my tv or should i use simple rcas?
Username: Project6
Post Number: 6149
Sorry lopro...satellite receivers are not my thing.
I think some people connect the SPDIF to the receiver.
Username: John_s
Columbus, Ohio
US
Post Number: 738
S/PDIF (Also SPDIF) Sony/Philips Digital Interface, a standard audio file transfer format. Developed jointly by Sony and Philips, S/PDIF allows the transfer of digital audio signals from one device to another without having to be converted first to an analogue. This prevents the quality of the digital signal degrading during transfer to analogue.
lopro, your receiver must be equipped with an s/pdif input. The AV receiver will then decode the digital audio being output by the sat receiver into stereo or surround, depending on what audio the specific channel is generating.
Username: Lopro
Post Number: 13
do the monster component cables provide audio? or only video??
Username: John_s
Columbus, Ohio
US
Post Number: 741
Component cables, Monster or otherwise, carry video only.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 23, 2006 > Wiring up reciever to Tv help.. [ « Previous ] [ Next » ]
