Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through June 05, 2006 > Help!!
Author Thread: Help!!
Username: Shamacala
i have just recently purchased a toshiba 42wlt58 tv & a toshiba sd350e dvd....i would like to purchase a 5:1 surround speaker system to link-up...is this possible??...if so, what is the best system to purchase??....how can i link up the speakers to enable both tv & dvd surround sound capability?? thanks in anticipation..
Username: Project6
Post Number: 5929
Yes it is possible.
Let us not worry about the "best". You'll find extreme difficulty in determining which would be the best.
Do you have a budget? What is available in your area? Are you willing to use internet companies?
Username: Shamacala
hi berny...thanks for your reply - my budget is £200 - my problem is that most speaker systems come "bundled" with a dvd player/recorder which i do not require - i purchased both my tv & dvd player from internet companies!!
Username: Project6
Post Number: 5990
Martin,
If you do not want a "bundled" system you are going to need a receiver and a separate set of speakers. You may end up spending more than your required budget.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through June 05, 2006 > Help!! [ « Previous ] [ Next » ]
