Thread: Help with hd system selector. |
New member Username: Shadowsdarknes
Post Number: 1 Registered: Feb-06
| Posted on Thursday, February 16, 2006 - 11:08 pm: |
I am trying to hook my game systems using an hd system selector. http://hardware.gamespot.com/Story-ST-13904-1247-x-x-x It comes with # 1 each: AV/S-Video Cable # 1 each: Component Cable I am trying to hook my playstation 2 and gamecube into it. Since it comes with component cables, will I be able to play games in 480p? I have a tv that is capable of doing that. I don't know how to set it up. The manual makes no sense to me and is now missing. Any help? |
Post Number: 5925 Registered: Dec-03
| Posted on Friday, February 17, 2006 - 06:55 pm: |
You can only get progressive signals if your sources are progressive scan output capable. If your games are capable of playing in progressive scan mode, then you should be able to see it in higher definition, if not then you won't |
Post Number: 2 Registered: Feb-06
| Posted on Saturday, February 18, 2006 - 07:15 am: |
OK. I am still unsure how to actually hook it up to get a picture. The provied links shows the front and back of the system. The component cable included is blue red and green on both ends of the cable. I don't know how to make it work. It says no need to plug it in. |
Post Number: 6005 Registered: Dec-03
| Posted on Saturday, February 18, 2006 - 06:55 pm: |
Do both your PS2 and GC come with component cables? If they do, then you just connect that to the switch. Then from the switch, you connect component cables to the TV's component inputs. |
Post Number: 3 Registered: Feb-06
| Posted on Tuesday, February 21, 2006 - 07:15 pm: |
No, they are regular composite cables. I have plenty of inputs. But when I first got it, I didn't. So I'm guessing progressive scan picture? I guess I have to buy ps2 component cables. |
Post Number: 6214 Registered: Dec-03
| Posted on Wednesday, February 22, 2006 - 02:36 am: |
Yes you will need component cables. |
Silver Member Username: Dirtfarmer
Alberta
Post Number: 662 Registered: May-04
| Posted on Wednesday, February 22, 2006 - 10:46 pm: |
berny you still at it arnie |
Post Number: 6248 Registered: Dec-03
| Posted on Thursday, February 23, 2006 - 07:48 am: |
Still at it, Arnie. How have you been? I have not read any of your posts in a while. We need you knowledge in the Home Theater section |
Alberta
Post Number: 665 Registered: May-04
| Posted on Thursday, February 23, 2006 - 10:50 am: |
believe it not ,i run out of think to say, lol and there closed, both the spot i did post to arnie |
Post Number: 6256 Registered: Dec-03
| Posted on Thursday, February 23, 2006 - 05:01 pm: |
