Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Sony DAV-S400 Sound Issue (none)
Author Thread: Sony DAV-S400 Sound Issue (none)
Hi,
I recently moved my equipment to a different part of the room but since then my surround sound has been cutting in and out intermittently.
When it doesn't work: I am limited to choosing the following sound fields HP THEATER or HP 2 CH STEREO, neither of which play the sound through the speakers.
When it works: I can choose from the 10+ sound fields and can hear everything through the speakers.
When silent (HP THEATER), if I push the speaker connections in real hard I hear a clicking sound inside the casing and the sound will come through the speakers. I know it sounds like a loose connection, but internally?
Any direction would be greatly appreciated.
Thanks
Username: Crispy
i also have discovered this problem that you encountered if you have recieved a solution to this i could do with some pointers myself and help please
Home > Message Board > Home Theater > Surround Sound > Archive through December 01, 2006 > Sony DAV-S400 Sound Issue (none) [ « Previous ] [ Next » ]
