Thread: Playing speakers when watching tv. NEED HELP! |
bvndafjghjd Unregistered guest |
| Posted on Tuesday, February 14, 2006 - 06:07 pm: |
I have recently purchesed a Durabrand home theater system (which is hooked up to my sony TV)and have used it several times when watching DVD's or hooking up my MP3 player to it and playing it through.I was wondering being a home theater beginner if you would say IS IT POSSIBLE TO PLAY THE SOUND ON TV THROUGH MY HOME THEATER SYSTEM SPEAKERS. Thank You for your time. |
Bronze Member Username: Praetorian
Post Number: 75 Registered: Dec-05
| Posted on Tuesday, February 14, 2006 - 08:20 pm: |
disconnect the the audio cables running from your cable box to the TV from the TV's end, and plug them into your receiver, then select the appropriate input. |
| Posted on Wednesday, February 15, 2006 - 04:40 pm: |
thank u so much 8^) |
| Posted on Wednesday, February 15, 2006 - 04:52 pm: |
the thing is my riecever doesnt have a cable input. 8^( is there somthing that i can buy which would allow me to have a cable input. |
| Posted on Thursday, February 16, 2006 - 04:59 pm: |
owwwwwwwwwwwwwwwwww now i got it Thnks u! |
